stm32f4xx_fmc
Posted on April 22, 2014 at 22:25Hi, I am looking for the V1.2.1 libs/headers especially for stm32f4xx_fmc and realted items. Thanks, Pepe
Posted on April 22, 2014 at 10:33Hello, STM32FCube changes the API to many calls, e.g. SD_Init(void) to HAL_SD_Init(SD_HandleTypeDef *hsd, HAL_SD_CardInfoTypedef *SDCardInfo), if I understand things right. This need substantial effort to port old co...
Posted on February 06, 2014 at 01:21Hi Everyone,Sorry if this is a repeat post, I'm pretty sure I've looked through all of the past discussions related to this and still have not found a solution.I designed a new board using the STM32F427 and have b...
Posted on April 22, 2014 at 04:17Dear all, I found in the STM32F10x_stdperiph_LIb file Stm32100_eval_lcd.c. This file is firmware driver for an LCD TFT with Hx8312 Controller. I want to use an LCD TFT of Newhaven Display with Hx8369 Controller (an ...
Posted on April 22, 2014 at 16:19Hi all, I'm trying to use the speex library on a STMF205. I have downloaded the AN2812 and the stsw-stm32017 example. I have copied code example into my project : /* Speex encoding initializations */ speex...
Posted on April 03, 2014 at 17:45Hello everyone, i am trying to design a board around STM32F407VGT6 and i want to use minimum components. i will not use the ADC for any purpose , is it possible to leave the pins related to it (VREF+,VREF-,VDDA,VSSA)...
Posted on April 15, 2014 at 22:08I found out that in my case the generated usbd_conf.h file contains a bug which is only visible when including it from a c++ file. The code contains the typical conditional 'extern ''C''' declaration at the beginning...
Posted on April 01, 2014 at 15:06 Dear List, I am working on IAP on the STM32F4Discovery board and flashing only occasionally works. I started from the example describing IAP using an USART. But I use USB to download the data...
Posted on April 14, 2014 at 18:48Hi All,Can anyone please advise why there is no VBAT pin on STM32L152 MCU?I read that RTC runs as long as the MCU is powered...but when its not, then what ?How to implement RTC backup supply on this MCU?Thanks!regard...
Posted on April 21, 2014 at 09:15Guys, STiH207I'm just wondering, where can I find the discussion for this chip ? thanks https://my.st.com/st-extranet-web-active/active/en/catalog/mmc/FM131/SC999/SS1629/PF252588Guys, STiH207Advanced dual HD AVC proc...
