vBAT circuitry for STM32L476RG
Posted on January 04, 2017 at 10:20Hi allI would like to connect a battery to vBAT Pin for my Nucleo STM32L476RG.I'm wondering if I should remove SB45 resistor or not.If anyone could tell me what's the correct steps to build a vBAT backup circuitry....
External Clock Problem
Posted on January 04, 2017 at 09:39Hi,   I am using STM32CubeMX and I want to use external crystal for clock. However, I face some problems,1) I set Baudrate 9600 for uart2 and send data to computer but in computer I can read the data with 4800 baud...
External oscillator STM32L476Jxx (Sensor Tile)
Posted on December 30, 2016 at 11:13I am designing a new custom board replicating Sensor Tile.The problem is STM32l476jxx (sensor tile) is not using external crystal for core clock. its uses Bluenrg reset pin on the external clock oscillator input p...
STM32H7 series - brutal raw power of 400MHz clock
Posted on October 20, 2016 at 11:10While I see no announcement, the following is online: http://www.st.com/content/st_com/en/products/microcontrollers/stm32-32-bit-arm-cortex-mcus/stm32h7-series.html?querycriteria=productId=SS1951 Not only the 400MH...
stm32h7 cube
Posted on January 03, 2017 at 16:18Would like to check out the STM32H7 chips,    See if they can do the combination of functions we want, On the F7, we used the cube software,     but H7 not supported ( yet ) in the cube.Any thoughts / idea when the...
GPIO Hal remap
Posted on December 22, 2016 at 14:14Hi. I'm trying to remap a gpio pin from out to it but the following lines of code don't work.Can someone help me?I need to remap GPIOx, GPIO_Pin from out to in on the fly.void DigitalInOut::SwitchToInput() {    HA...
Resolved! F103 and F072 SPI communication
Posted on January 03, 2017 at 09:44I am trying to communicate with a device (a radio module which has inside STM32F103 MCU ) with my STM32f072B disco board using SPI I can program the radio module almost as a standard STM32 MCU the only difference i...
ionutF by Associate III
  • 1655 Views
