USB device vs USB OTG for android USB communication
Posted on December 18, 2017 at 12:50Hello,I'm working on a project where I have to exchange small data with an android phone with an electronic board using USB communication and charge it in the same time.I have only used USB CDC class  to connect w...
STM32F767 LL SRAM Example
Posted on December 18, 2017 at 11:22Hello, since I had no luck with HALL drivers, i started to look into LL libraries.It is shame, that where is no example for each peripheral, it would make it so easy to implement.Does any body has SRAM example ? I...
VSSA/VDDA is not connected to VSS/VDD
Posted on December 11, 2017 at 15:14Hello,we're currently investigating a problem with one of our products, which seems to stall sporadically at a customers site. The used controller is STM32F103VE. I've detected at least one potential problem in ou...
STM32F215VG USB host example
Posted on December 18, 2017 at 08:20Hi,I  am looking for an example code for USB host implementation in STM32F215VG. I have the STM32Cube SDK available with me.  But example given in that are for some other processors. I am looking for example for t...
Roshin K by Associate
  • 584 Views
USB HID+PID application
Posted on December 18, 2017 at 07:36Hi all,For an application i need to interface the micro controller(STM32) which is having USB port work as Mass Storage device and Keboard HID device.Device needs to work parallel for HID and PID. Is there common ...
Resolved! A new faster STM32 Arm?
Posted on December 16, 2017 at 16:26I read that there will be a new much faster chip in the first half next year. What's the name of the chip(s) and is there more info about it available?
LMI2 by Lead
  • 2104 Views
Resolved! Hi all, is there a way to dump a make file from STM32CubeMX?
Posted on December 16, 2017 at 21:43I found this link but I can't figure out how to do it:https://community.st.com/external-link.jspa?url=https%3A%2F%2Fhackaday.com%2F2017%2F07%2F15%2Fstm32cubemx-makes-makefiles%2FI'm running on Windows but I'd like...
scott h by Associate II
  • 4282 Views
STM32F7 SRAM interface non functional (bug in Hall?)
Posted on December 17, 2017 at 11:34Hello.I have STM32F767 interfaced with FPGA with 32b SRAM interface ( same board STM32F479, and it works extremely well)I checked IO pins, at the moment only CS, toggled it manually, FPGA can see it at 109MHz, no ...
