STM32F4 DMA quetion
Hello everyone.I'm studying in STM32F4 and learn DMA module using Example code of St. The example show how to use DMA in Burst feature to do 3 transfers into timer register beginning at TIMx_ARR after DMA update request.But I don't understand why add...
Resolved! SBSFU warning: Initialization with factory default values
Posted on July 15, 2018 at 09:26Hi,SBSFU gives me the warning 'SECURE ENGINE INITIALIZATION WITH FACTORY DEFAULT VALUES' on every new power-up of the microcontroller. Is this behavior normal after a power-cycle or is anything not configure correctly...
Resolved! About voltage scaling 1, 2 ,3
Hello,I am working on Power Reduction and we are using STM32F446RE Microcontroller. In the RM i found this, "the regulator output voltage (around1.2 V) can be scaled by software to different voltage values (scale 1, scale 2, and scale3 can be configu...
RN by Senior
  • 6637 Views
UARTS
Hello, I am using NUCLEO F49ZI. I am trying USART for Modbus Master. So after I send command to slave device, I would like UART to be listening mode or receiving mode. however, I confuse USART2_IRQHandler() and HAL_UART_Receive_IT(&huart2, pdata, 2...
yang hong by Associate III
  • 797 Views
STM32L476 I2C problem
Hi All,I've been struggling with this for a while now. I have designed a new board based on the STM32L476 to replace an old design using a PIC. I cannot for the life of me get the I2C to work.I have used STMCubeMX to pinmux and configure / generate...
