SPL2LL-Converter Out of memory
Hi,I'm trying to covert old drivers to new ones.I use the SPL2LL converter tool.Folder size to be converted is ~71MByte.I get "Out of memory" error. What should I do?Please fins attached snapshot.Thanks,Aviv
AFink by Associate III
  • 3093 Views
Hi Friends, I am trying to generate the audio by using STM32F103C8T6 board . I am using raw wav data. I configured TIM2 to generate 8Khz PWM pulse . when I am attaching the speaker to PA0 Pin only some tic and noise sound generate. Please help me.
//The wav sample format is from 8bit sound, 8K Hz in an hexadecimal converted arrayThe given below is details of my TIM2 Init function.static void MX_TIM2_Init(void){ TIM_MasterConfigTypeDef sMasterConfig; TIM_OC_InitTypeDef sConfigOC; htim2.Instance...
Buffer size error when compiling the embedded webserver on STM32F7 with a different display image than provided. Any ideas?
I am running the embedded web server on the STM32F7 and I changed the linked image that is displayed on the MCU. It compiles, but doesn't display. After investigating, a buffer size error is being thrown and consequently the main code gets stuck in...
TSnyd by Associate
  • 776 Views
Access ETM only with code without the use of debug kits
My board is Nucleo F401RE. This is the first time I've ever been doing this.I am using a pointer to the main registry of ETM, its address I read it on the datasheet.My problem is that wanting to change the bits of this log I do not change it the corr...
LRusc by Associate
  • 642 Views
