Resolved! Avoid 1 second delay in RTC every power off/on.
Posted on January 03, 2018 at 10:44Hi again,I'm using an RTC as I explained in https://community.st.com/0D50X00009XkWttSAF.Our device have a battery in VBAT, so the RTC still works when the device it's power off. But after a power on the RTC can los...
Resolved! Device bus cycles (STM32F427)
Is there a document that discusses the buses?I was wondering how much Chrome-Art might affect Flash-Art and CPU, if a picture is stored in flash.How many bus cycles Chrome-Art takes for a transfer and how does Flash-Art access the flash.I'm working o...
Is eeprom emulation possible on the stm32h750?
FromRM0433: STM32H743/753 and STM32H750 advanced ARM®-based 32-bit MCUs Reference Manual PDF3.3.4 Flash memory architecture and usage• For STM32H750xB devices: a 128-Kbyte user Flash memory block containing one user sector of 128 Kbytes (4 K Flash wo...
ETone by Associate III
  • 1629 Views
STM32F1 ETH UDP TX loosing packets
In my project i have a ethernet communication in between a PC and a STM32F107 uC device. When everything works fine the PC sends a request to the uC-Device and this one sends a echo back to the PC when everything from the request is done. Because of ...
MathiasZ by Associate II
  • 2514 Views
SD Card on the IDW04A1
Hi, I am using the IDW04A1 WiFi module for a project where I want to transfer potentially large files to a server. Is there a way of accessing the SD slot from my MCU? I am using the STM32F401RE MCU and currently I use an external SD to save files. I...
