Running any STM32 IDE as a cloud service ?
As some of you have noticed in previous questions, I have a rather unique problem in that my code has to be modifiable by the end-user, who is more of a hacker than computer expert, can usually handle a PC so can use something like Arduino but may no...
MikeDB by Lead
  • 2805 Views
Resolved! Pin to pin Replacement of STM32F030C6T6TR.
Hello All,Currently, we are working on STM32F030C6T6TR controller, it has 32KB flash memory & this memory is not sufficient for our application.We do not have sufficient time to design the PCB again. Please suggest any other controller with the large...
SPraj.15 by Associate II
  • 3043 Views
Analog read is not returning the maximum value
Hi there.I was making some tests and I have observed that, when I shortcircuit 3V3 into my analog pin (in this case PA0), the reading I'm having is 4022 instead of 4095.Why this difference? I'm using HAL libraries as follows://Function to obtain ADC ...
areify by Associate II
  • 4533 Views
Can someone explain how to read these line ?
Hello everyone !I'm new here and i wanted to know how these lines say please??I wanted to have microsecond delay for my ultrasonic sensor.Thanks for all your help!void usDelay(uint32_t uSec) { if(uSec < 2) uSec = 2; usTIM->ARR = uSec - 1; usTIM-...
MDMA read from DTCM - transfer error
I'm trying to move an array from DTCM to SRAM1.So I use MDMA in as memery to memory config. It isn't my first time I got it running, but never used it to transfer data from/to TCM region.I want to copy array at 0x20000018 starting address (DTCM regio...
AB.17 by Associate II
  • 804 Views
STM32L063C8U6 pinout
I have bought STM32L063C8U6 (version in UFQFPN 48 package) but I can not find pinout in datasheet. DS10090 version 7 does not mention any UFQFPN package.Also SMTCubeMX says that "cannot load this MCU). Is this version secret?Thanks for answer, Jiří ...
JNeto by Associate
  • 1207 Views
Support for STM32TS60?
Hello,Is it possible to get technical support for STM32TS60? I have some specific questions and would also welcome project files / BSP.BRNiclas
NArnd by Associate III
  • 1036 Views
