RC Radio PWM signal, problems reading
Hi,Im trying to resurrect this project from 2015 (Software AWD control for RC Cards using 4x brushless motors):https://github.com/hammerfet/BrinirControllerIve built his VS2013 solution and got all that side working fine. However, next is to determin...
ADevi.1 by Associate II
  • 4335 Views
STM32H7A3RIT when?
Can anyone from ST let me know when and if the STM32H7A3RIT (64-pin part) will be available. This is an important part that can be extremely useful in a large range of applications allowing much smaller form factor for the application than the parts...
PMath.4 by Senior III
  • 852 Views
Sizeof(array) function
Hello,A simple question make me confused. For example, this code with return 40 value for a 10-member array.#include <stdio.h> int buffer[10]; int main() { printf("Hello World %d \n\r",sizeof(buffer));   return 0; }For settings my DMA for sp...
parisa by Senior
  • 6031 Views
Resolved! where can I find the register addresses for STM32L476RG?
Hi,I have a STM32L476RG board and I try to execute the following program, obtained from this web http://www.microdigitaled.com/ARM/STM_ARM/Code/Ver1/Chapter02/Program2-1.txt which is for a different Nucleo 64 board (STM32F446RE)/* p2_5.c Toggle Green...
MFaun.1 by Associate II
  • 7679 Views
  • 14 replies
STM32F469 CAN Rx Issues
Hello, I am attempting to transmit a simple CAN message between two STM32F469I discovery boards. I am using the official STM32F4 github as reference found here: https://github.com/STMicroelectronics/STM32CubeF4/tree/master/Projects/STM324x9I_EVAL/Exa...
Header files required for programming STM32F446 MCU in C
I am new to ARM processor and I need to know what are the header files required in main.c for programming the above MCU in C by just accessing its registers (and manipulating bits) as explained in RM0390 (REFERENCE MANUAL for STM32F446xx) ?NOTE: I am...
STehA.1 by Associate II
  • 6592 Views
