Application cross two Bank, possible?
For stm32h7b3 , there are two Bank of flash, and each 1M, We are designing a big application which code size may exceed 1m.So may I know if possible to ​use two bank for this application? Any limitations for it?Or if possible to put application to ex...
jiangpen by Associate II
  • 1611 Views
Resolved! FMC interfacing lcd screen minor issue
I have nearly managed to interface one lcd screen(ili9341 16bit parallel fmc intel 8080 protocol) with my stm32 device but I am stuck at the very last step.I have connected the screen wires to the mcu , I have configured fmc from cube mx correctly , ...
SMour.1 by Associate III
  • 3205 Views
Unable to Communicate STM32G4 Nucleo-32 with SPS30 in I2C Mode!
Having difficulty to communicate with SPS30 on I2C. As a beginner I am having difficulty to understand how to debug the problem as it just returns 255 in in_buff. This topic may sound to broad, however, If someone can guide me the direction to make ...
PJ.3 by Associate
  • 1438 Views
Resolved! high temperature rugged MCUs? (250º)
Anyone has experience with this, does ST have anything that works beyond 105ºC?I saw cheap non Flash based 8bit mcus (Z86C04/C08) that go up to 125º-150ºAlso (TK68HC811E2) up to 175ºCI also found an article recommending chips worth 800€/piece555 chip...
Javier1 by Principal
  • 3343 Views
Resolved! ¿How to SWD (Serial wire) as a Master/host from STM32?
Good morning everyone.Any tips,toughts, links to documentation ....describing how to use the SWD protocol as a master? I found this page describing the SWD protocolIs there any stm32 product with master SWD capabilities in their peripheral?STlinks ar...
  • 3210 Views
Software Reset Only Occurs Once
I am using the STM32H753VIHX. I am using NVIC_SystemReset() to trigger a system reset under fault conditions. This only works once though. I am line by line debugging my code and when I flash the code to the controller and step to my test fault it su...
emwp by Associate II
  • 1174 Views
