STM32F4 Gated Timer with TIM2_CH3
I want to count the 'high time' of a signal on TIM2_CH3. I simply want to count up TIM2 by using internal clock, but gating it with TIM2_CH3. I don't care about interrupts; I only want to use the counter value to access how much 'activity' has occurr...
SS13 by Associate II
  • 1529 Views
one Timer PWM, 2 LEDs
Hey thereI want to use one and only one Timer to generate PWM signal to control 2 LED lights. assume that PWM generated is only attached to one the LEDs. how can I make both of LEDs shine or dim with only one PWM?thanks in advance for any help and hi...
Ala by Senior
  • 3318 Views
QSPI flash not read in S25FL512 with STMH743
hi, i want read read and write data from external QSPI flash S25FL512.i posted code from below st linkhttps://www.st.com/content/st_com/en/support/learning/stm32-education/stm32-moocs/external_QSPI_loader.html QSPI_READ and QSPI_write function exec...
ykn by Senior
  • 1630 Views
Cannot read low current consumption on STOP2 mode with my STM32L412 board (~300uA+-), but using the same code and compatible with my STM32L476, i succeed (~3uA). ill be happy to work with low consumption with the STM32L412, can any one help me with that?
Hello guys, first, i would like to thank you about this forum i used a lot and got good suggestions and i learn a lot from you.About my problem:I checked a lot in the internet and see others that had the same problem like mine, but didnt find any wit...
Ypinh.1 by Associate III
  • 1485 Views
Frame synchronization randomly swapping.
I have a STM32L433 driving a FDA802 using SAI in I2S standard mode, and it randomly swaps the left and right channels. I have compiled with a small table of interleaved data (two sine waves of different amplitudes) to try an fault find. the code I am...
KJans.1 by Associate II
  • 1716 Views
