Hi, I'm trying to use 4 ADC channels on STM32L152RE but it seems there are some problems with HAL_Delay and Hal Gettick... if I use only 2 channels it works.
What debugging/investigation have you done to find the problem?
A complex system that works is invariably found to have evolved from a simple system that worked. A complex system designed from scratch never works and cannot be patched up to make it work.
