2019-09-16 8:11 AM
2019-09-16 1:37 PM
What exactly does the ADC output at such input voltage? Did you try on multiple pins? Does the sampling time setting influence the result?
Do you test this on a "known good" board such as a Nucleo/Disco, or your own board? In the latter case, could you run the test on a Nucleo/Disco?
