2024-01-10 7:11 AM
hi guys,
I'm a desktop programmer and do not know much about micro controllers and electronics but i am very interested in making an oscilloscope which:
- simple to build with well known parts and ICs
- it uses bluepill as the ADC and no other ADCs
- it be able to measure negative voltages
- It uses near maximum ADC sample rate possible from bluepill
Single channel would be enough for above spects. recently I was working with a cool project named rp2daq which convert RPI Pico to a 500KSps /12Bit resolution and uses USB to send data to PC.
I did try to make a proof of concept version of a oscilloscope on top of it and it did worked (kind of) available from here.
I was using this simple oscilloscope since last day which i gave 10v signal to it's ADC by mistake and it broke.
The pico is expensive relate to blue pill (in my area, 3x more expensive), so i am thinking if anyone interest in making such open source scope, i think I can fully do the desktop part and need help for the micro controller side.
Or at least you could give me some guidelines for that.
Thanks
2025-04-18 1:23 AM
ST resources are only dedicated to supporting genuine ST products. We are not committed to ensuring that clones/fakes products work properly with the firmware we provide.
We suggest to purchase a genuine products and purchase them from known and trusted distributors.
Thank you for your understanding.
