2025-02-16 12:19 PM
I am trying to control a 24V PMSM type motor using ST Motor Control Workbench version 6.3.1 with the FOC.
I have run Motor Profiler and then gotten the electrical and mechanical parameters.
I have three questions and can anybody help/answer them?
Thanks in advance.
2025-03-12 7:35 AM
Hello @EDokm,
You can profile your motor alone. In this case, once loaded, speed/torque regulator PID gain tuning has maybe to be done.
You can also profile the motor loaded if the profiler sequence isn’t a risk in your case (gear box or fan use case for example).
2025-03-12 7:35 AM
Hello @EDokm,
