2021-02-20 9:29 AM
Hello Team,
I am using st mc workbench to create a code for PMSM Motor control but when I am trying to generate the code then I got some java related issue and even I have already updated java version are present
2021-03-01 11:59 PM
Dear @NMish.1
I move your text from title to description.
Best regards
Laurent Ca...
2021-03-02 12:03 AM
Dear @NMish.1
Did you check that old java version are not remaining on your system after update?
Did you try to re-install or update STM32CubeMX tool version?
Best regards
Laurent Ca...
2021-06-01 8:51 AM
The question has been moved from the "Motor Control Hardware" section to the "STM32 Motor Control" section (the question is about the STM32 MC SDK).
Best regards
Laurent Ca...
2022-04-18 10:14 PM
Same issue here also,
Could you please tell the solution?
