Motor profiler cannot recognize brushless coreless motors
滴滴答
Associate
Motor Proiler 识别无刷空心杯电机的时候,卡在28%,套件用的是
Translation:
When the Motor Profiler identifies a brushless coreless motor, it gets stuck at 28%. The kit uses...
1 ACCEPTED SOLUTION
Accepted Solutions
STuser2
Senior III
Check the MCSDK documentation in the above section.
2 REPLIES 2
STuser2
Senior III
federico.rodighiero87
Associate III
I used it on coreless motor, motor profiler is not mandatory. What motor are you using ?
HW/FW Motor Control Engineer
https://www.linkedin.com/in/federicorodighiero/
