2022-05-03 2:42 AM
The error is for the UART communication between the STM32F303 control board and the ST Motor Pilot software, but what does it mean exactly ? Where can I find information about such errors ? My best guess is that there is a problem with a buffer for the UART, but is the problem due to my PC ? Is the baud rate to high ? Is it due to using the high frequency plot feature in the Motor Pilot software ?
2022-06-15 7:44 AM
Hi I'm having the same problem, did you solve the problem? if you solved the problem, can you help me ?
