2024-10-30 1:30 AM
2024-10-30 16:22:59,914 DEBUG [Main.lambda$run$0] Arguments: [-ioc, E:\Document\Ufactory\xArm\SDK\jointMotor\850\st_afr\Noname\Noname.ioc, -xdm, E:\Document\Ufactory\xArm\SDK\jointMotor\850\st_afr\Noname\Noname.wb_def]
2024-10-30 16:22:59,925 DEBUG [ArgsValue.readPropertiesFile] [AppConfig] pack.source = "D:\Sofeware\Program\DriveTool\STM32_MCSDK\Soft\MC_SDK_5.Y.4\Middlewares\ST\MotorControl"
2024-10-30 16:22:59,931 DEBUG [ArgsValue.readPropertiesFile] [UserConfig] pack.source not found
2024-10-30 16:22:59,931 DEBUG [ArgsValue.getConfigProperties] pack.source = "../../../../Middlewares/ST/MotorControl"
2024-10-30 16:22:59,943 DEBUG [ArgsValue.lambda$retrieve$2] CLI_ARG[xdm]: E:\Document\Ufactory\xArm\SDK\jointMotor\850\st_afr\Noname\Noname.wb_def
2024-10-30 16:22:59,943 DEBUG [ArgsValue.lambda$retrieve$2] CLI_ARG[ioc]: E:\Document\Ufactory\xArm\SDK\jointMotor\850\st_afr\Noname\Noname.ioc
2024-10-30 16:22:59,945 DEBUG [ArgsValue.retrieve] {xdm=E:\Document\Ufactory\xArm\SDK\jointMotor\850\st_afr\Noname\Noname.wb_def, updftl=templates/wb_ioc_mc-middleware.ftl, mx_timeout=-1, exp=templates/wb-defines_where_and_what.txt, ioc=E:\Document\Ufactory\xArm\SDK\jointMotor\850\st_afr\Noname\Noname.ioc, pack=../../../../Middlewares/ST/MotorControl, ftl=templates/wb_ioc_template.ftl}
2024-10-30 16:23:00,077 DEBUG [Main.run] Targeted MCU family = F4
2024-10-30 16:23:00,125 DEBUG [Main.run] Minimum associated CubeMx to the `F4` targeted MCU family is `4.25.0-a0`
2024-10-30 16:23:00,170 DEBUG [WindowsCubeMxFinder.lambda$findThem$2] Found 64-bit subkey HKEY_LOCAL_MACHINE\~~~\Uninstall\STM32CubeMX
2024-10-30 16:23:00,172 DEBUG [WindowsCubeMxFinder.lambda$findThem$2] Found 64-bit subkey HKEY_LOCAL_MACHINE\~~~\Uninstall\STM32CubeMX(1)
2024-10-30 16:23:00,183 DEBUG [CubeMxCtx.EXE_version] Loaded path: 'D:\Sofeware\Program\Cubemx\Sofe\STM32CubeMX.exe'
2024-10-30 16:23:00,183 DEBUG [CubeMxCtx.EXE_version] Loaded updater jar: 'D:\Sofeware\Program\Cubemx\Sofe\plugins\updater.jar'
2024-10-30 16:23:00,208 DEBUG [CubeMxCtx.EXE_version] Loaded path: 'D:\Sofeware\Program\Cubemx\S6.9\STM32CubeMX.exe'
2024-10-30 16:23:00,209 DEBUG [CubeMxCtx.EXE_version] Loaded updater jar: 'D:\Sofeware\Program\Cubemx\S6.9\plugins\updater.jar'
2024-10-30 16:23:00,254 DEBUG [CubeMxCtx.EXE_version] Loaded path: 'D:\Sofeware\Program\Cubemx\Sofe\STM32CubeMX.exe'
2024-10-30 16:23:00,255 DEBUG [CubeMxCtx.EXE_version] Loaded updater jar: 'D:\Sofeware\Program\Cubemx\Sofe\plugins\updater.jar'
2024-10-30 16:23:00,256 DEBUG [CubeMxCtx.EXE_version] Loaded path: 'D:\Sofeware\Program\Cubemx\S6.9\STM32CubeMX.exe'
2024-10-30 16:23:00,257 DEBUG [CubeMxCtx.EXE_version] Loaded updater jar: 'D:\Sofeware\Program\Cubemx\S6.9\plugins\updater.jar'
2024-10-30 16:23:00,289 DEBUG [CubeMxCtx.EXE_version] Loaded path: 'D:\Sofeware\Program\Cubemx\Sofe\STM32CubeMX.exe'
2024-10-30 16:23:00,290 DEBUG [CubeMxCtx.EXE_version] Loaded updater jar: 'D:\Sofeware\Program\Cubemx\Sofe\plugins\updater.jar'
2024-10-30 16:23:00,294 DEBUG [CubeMxCtx.EXE_version] Loaded path: 'D:\Sofeware\Program\Cubemx\S6.9\STM32CubeMX.exe'
2024-10-30 16:23:00,294 DEBUG [CubeMxCtx.EXE_version] Loaded updater jar: 'D:\Sofeware\Program\Cubemx\S6.9\plugins\updater.jar'
2024-10-30 16:23:06,230 DEBUG [CubeMxCtx.EXE_version] Loaded path: 'D:\Sofeware\Program\Cubemx\Sofe\STM32CubeMX.exe'
2024-10-30 16:23:06,230 DEBUG [CubeMxCtx.EXE_version] Loaded updater jar: 'D:\Sofeware\Program\Cubemx\Sofe\plugins\updater.jar'
2024-10-30 16:23:06,238 DEBUG [CubeMxCtx.EXE_version] Loaded path: 'D:\Sofeware\Program\Cubemx\S6.9\STM32CubeMX.exe'
2024-10-30 16:23:06,239 DEBUG [CubeMxCtx.EXE_version] Loaded updater jar: 'D:\Sofeware\Program\Cubemx\S6.9\plugins\updater.jar'
2024-10-30 16:23:06,299 DEBUG [EnvironmentChecker.checkPack] STM32CubeMX.Version: 6.12.1-RC4
2024-10-30 16:23:10,342 ERROR [LineInfo_to_exitCode.manage_MCPackNotFound] MotorControl reference pack not found: "../../../../Middlewares/ST/MotorControl"
2024-10-31 3:29 AM
2024-10-31 3:29 AM
