2021-10-12 12:53 AM
Hi, I have few questions regarding ST motor control library and hardware/motor compatibility.
2021-12-08 2:48 AM
Dear @Community member
Have you managed to solve your problems in the meantime?
Best regards
2021-12-16 4:51 AM
@Laurent Ca...
Not really, no.
I managed to spin one motor using F303RE Nucleo Board + IHM16M1 using new library 5.Y although can't get single motor to run properly using library version 5.4.6 (which i have to use for IHM042V1 board).
My questions still stands though (especially first one). Am i wasting my time trying to spin 2 of those Maxon motors(i can include datasheets if needed) using IHM042V1? Maxon recommends minimum of 50khz PWM frequency and i can't set it higher than 20-24k. Increasing execution rate does not help either.
I can try and make my own board using G4 MCU family (and for example external components if those embedded in F3/G4 are not fast enough for my use-case) if there is any chance it would improve things.
Will there be support for dual drive systems in upcoming library version 6?
