2020-07-30 12:15 PM
Hello, I am a novice programmer. I have a problem with EVSPIN32F0601S3.
I cannot compile the program generated by ST Motor Control in any way - whatever I would not do, an error pops up:
"Make: *** No target rule" ../Middlewares/MotorControl/inrush_current_limiter.c ", needed by" Middlewares / MotorControl / inrush_current_limiter.o ". Stop. The problem with the C / C hard drive "
ST MOTOR CONTROL shows no error.
And I can't connect via ST Motor Control to EVSPIN32F0601S3 board (I can via IDE and others).
Can someone help me with this problem or indicate where I can look for a solution?
2020-10-20 8:10 AM
Dear @Kamil Wroński
Any news?
Best regards
Laurent Ca...
2020-10-22 12:59 AM
@Kamil Wroński
Please, could you share with your Motor Control setup configuration, as well as the tools version used ?
Thanks a lot,
Best Regards,
PBo
2020-11-02 12:37 AM
Dear @Kamil Wroński
As you do not answer, I guess you don't have to solve this problem anymore, therefore I consider this thread closed.
If not, feel free to reopen it by posting a new answer.
Best regards
Laurent Ca...
