2023-11-23 2:20 AM
Hi All ,
I need to change phase 120 degree to 90 degree in MotorControl Workbench 6.2.0
Can change in file mc_math.c?
For use single phase motor 3 wire
Please help me for advice.
BR,
METHEE
2023-11-24 6:25 AM
Hello @methee_c
I am not an ACIM expert but your motor sounds weird to me.
You mentioned single phase? three wires? and an angle of 90 degrees...
Do you have any commercial reference of your motor I can look at?
Cedric
2023-11-23 2:39 AM
Do you use FOC (sensored / sensor less) , 6 step commutation? What you want to change in mc_math.c?
2023-11-23 9:28 AM
Hi SRedd.5,
I test run on ACIM open loop,I see table and config in mc_math
You can help me for Change phase 120 degree to 90 degree in MotorControl Workbench 6.2.0?
BR,
METHEE
2023-11-24 6:25 AM
Hello @methee_c
Cedric
2023-11-27 2:01 AM
Hi cedric H,
I changed pole = 2 from looking at the machinery. normal current.
Thanks you,
Methee
