2025-03-15 12:37 PM - last edited on 2025-03-17 8:18 AM by Andrew Neil
Hello i want to build a drone esc. So I need to control 4 bldc motors with a mcu. How would i do this? In the MC Workbench i can only select 2 Motors max.
2025-03-17 8:16 AM
Hello @QuirinS,
Referring to this post, B-G431-ESC board could be a solution.
It’s possible to control the B-G431-ESC board from a PWM input to vary the speed with the Electronic Speed Control. You can, for example, have 4 B-G431-ESC boards and one central control board.
