2025-07-16 2:51 AM
I was trying to configure WRP protection in the flash for page 0 to page 11 and I am using STM32L443VC MCU.
But I am seeing different value in the FLASH_WRP1AR for WRPstartoffset = 0x80 --Expected(0x00). Please find attached snapshot for the reference. Please do check the code snippet as well and let me know any configuration am I missing?
2025-07-16 3:07 AM
Hello @Rakesh936,
You must set the FLASH_WRP1AR register fields as follows:
After that, you must reload the option bytes by setting the OBL_LAUNCH bit in the flash memory control register.
This step is essential for the new WRP configuration to take effect.
Also, make sure RDP is not set to Level 1 if you need to modify flash
2025-07-16 8:34 PM
Hi @Sarra.S
I tried flashing the code with the above settings with the .hex file. I am using segger Jlink for flashing and Jflash tool. Even after flashing I am able to erase the flash. But I see WRP is detected in the device please check the snap for the reference. Can you please tell me how to flash using Jlink for WRP?. Thanks in Advance.
