VDM issue: PE_SEND_NOTSUPPORTED on STM32G071RB + SNK1M1 sink mode
vladovlado
Associate II
I am trying to get any communication with the source through VDM messages on my STM32G071RB + SNK1M1 setup and I am not able to. The source sends a request "VENDOR_DEFINED VDM:SVDM_DISCOVER_IDENTITY INIT" but PE on the sink responds with PE_SEND_NOTSUPPORTED. Power delivery works fine and manages to negotiate different power options.
The code is generated with CubeMX following this step-by-step guide: https://wiki.st.com/stm32mcu/wiki/STM32StepByStep:Getting_started_with_USB-Power_Delivery_Sink
I followed the manual (https://www.st.com/resource/en/user_manual/dm00598101-managing-usb-power-delivery-systems-with-stm32-microcontrollers-stmicroelectronics.pdf) chapter 4.5 and enabled these VDM features.
To implement the VDM callbacks and some DPM callbacks I used this repo: https://github.com/STMicroelectronics/STM32CubeG0/blob/master/Projects/STM32G0C1E-EV/Demonstrations/Modules/ucpd/
I am aware that there isn't sufficient hardware support for alternate modes on my current hardware but shouldn't it be possible to start negotiating?
Why does the stack reject the VDM message if they are enabled? The VDM callbacks never get triggered by the stack.
My goal is to just get it to communicate past the first message.
Also, UCPD Monitor doesn't display anything in Port Configuration under VDM SOP.
Kind regards,
Vlado
2 REPLIES 2
vladovlado
Associate II
Update:
here is the whole project for reproduction.
FBL
Hi @vladovlado
Sorry for my late reply. if still having the same issue, VDM callbacks never get triggered by the stack.
Did you enable the PE_VDMSupport in your DPM_Settings? Check in USBPD_VDM_UserInit ports being used.
Best regards,
FBL
