[stm32u585] HAL_IWDG_Init reconfig does not take effect
lll
Associate III
hello,
I encountered a problem while developing for stm32u585.
I change the iwdg reload value by HAL_IWDG_Init(), and then HAL_PWR_EnterSTANDBYMode(), but the new reload value does not take effect:
    hiwdg.Instance = IWDG;
    hiwdg.Init.Prescaler = IWDG_PRESCALER_64;
    hiwdg.Init.Window = 4095;
    hiwdg.Init.Reload = 3600;
    hiwdg.Init.EWI = 0;
    HAL_IWDG_Init(&hiwdg);
    HAL_IWDG_Refresh(&hiwdg);
    HAL_Delay(300);  //more than one downcount
    HAL_PWR_EnterSTANDBYMode();
if delay before refresh, it seems work
    hiwdg.Init.EWI = 0;
Is this the correct process ? If I want to ensure the modification is successful, what should I pay attention to
1 ACCEPTED SOLUTION
Accepted Solutions
Saket_Om
Hello @lll
after changing the IWDG prescaler/reload, the new configuration is not guaranteed to be fully effective if you enter STANDBY immediately. Even though HAL_IWDG_Init() waits for update flags, the IWDG (running on LSI in another clock domain) needs a short time to synchronize internally. Therefore, your second sequence is the correct approach: add a small delay after HAL_IWDG_Init() and before the first HAL_IWDG_Refresh() / HAL_PWR_EnterSTANDBYMode(), to ensure the new reload value is properly taken into account.
Saket_Om
2 REPLIES 2
Saket_Om
Hello @lll
Saket_Om
LSI=32K, prescaler=128 ==> IWDG=250Hz
before: prescaler=64, reload=40
after: prescaler=512, reload=3600
if i only config once, i need to delay about 3s. if i config twice, it seems that only a delay of 300ms is needed:
    hiwdg.Init.EWI = 0;
    HAL_Delay(350);
    hiwdg.Init.Prescaler = IWDG_PRESCALER_512;
    hiwdg.Init.EWI = 0;
is this sequence correct?
