2026-04-22 2:08 PM
Hello, is it possible to boot FSBL and load application from SD card upon powerup, bypassing onboard flash? I didn't see any clear guides on this procedure.
Thank you
2026-04-23 2:31 AM
Hello @Cococarbine
Please refer to the article below. This article provides a quick tutorial on how to use the FSBL to copy the application from an external serial NOR FLASH to an external serial PSRAM.
How to execute code from the external PSRAM using ... - STMicroelectronics Community
