2016-02-15 10:28 AM
Greetings to all!
Someone to do on this devbord SMD device? What HAL use, or just STM32Cube for this approach? I programmed the chip using STM32CubeMX, set to 8MHz external resonator, the cable is connected, but does not work. I tested on a devboard with a chip STM32F103C8, where it worked the first time. Maybe need to close the jumper SB24 and SB25? #usb #msd #stm32cube2016-02-21 10:37 PM
All works, sorry.
