2021-09-07 12:47 AM
I’m trying to use example from stmCubeIde (LwIP_TCP_Echo_Server LwIP TCP Echo Server Application) for NUCLEO144 with stm32h723zg, this application return the echo of the inserted character.
I try to use putty (with ip and port) and it works, the problem is that in the example is used echoserver to resend the character that the user write in putty, instead i need to save the character in a buffer to manage, have you got ideas or code for this?
Thank you very much.
2021-09-08 6:14 AM
Hello @GNobi.1 ,
Could you give more clarification about your use case ?
BeST Regards,
Walid
