STM32G031F8P6 VREFINT reading zero during DMA conversion while VSENSE working correctly.
Dunk
Associate II
Using DMA to read 3 ADC channels. IN0, VSENSE & VREFINT all enabled in CUBEMX. First 2 channels read as expected but for VREFINT it seems to always read zero. Am I missing a setting in the CUBEMX?
1 ACCEPTED SOLUTION
Accepted Solutions
Dor_RH
Hello @Dunk,
Could you try to have a look at the ADC_MultiChannelSingleConversion example: Link(here)
It contains an .ioc file that will be helpful for your application.
I hope my answer has helped you. When your question is answered, please select this topic as the solution that answered you, as it will help others find that answer faster.
Thanks for your contribution.
Dor_RH
2 REPLIES 2
mƎALLEm
1- What if you change the ranking by swapping VSENSE and VREFINT ranks?
2- Check if VREFEN bit is set in ADC_CCR register. From the reference manual:
I know you are using CubeMx to generate the code, but we need to ensure the code is well generated as well.
Dor_RH
Hello @Dunk,
Dor_RH
