2017-10-09 7:47 AM
Hello .,
I am working with STM32F765BIT MCU in our custom board. In this I need to make Ethernet interface working with any of protocol (like UDP).
I have generated code using STM cube , but I am not sure that I am fallowing correct procedure while generating code.
>> Even I couldn't able to ping from PC. Can you please give me some brief explanation on procedure to get working code, I am using LAN8710 External PHY, I can able to read write PHY registers ,but couldn't able send/receive any data from PC.
Can anyone please provide any example which corresponds to mentioned device (either you can provide Cube MX file or example code), so that I can proceed further easily .
Thank you.,
#stme32-cube #ethernet-stm32f7 #mcu2017-10-10 4:00 AM
The STM32CubeMX application does not generate usable code for ethernet. Take a look at the examples from the cube repository and rip what you need from ethernetif.c
2017-10-14 6:08 AM
Hello
doe.john.016
.,Thanks for your suggestions.
As per your suggestions I used some API's by taking reference from cube repository, Now I could able send & receive UDP packet from PC. but now the problem is the system is not reliable that is if I restart the device sometimes works and sometimes its not working. I really couldn't able to sort out exact problem .
Is there any problem exist inSTM32Cube FW_F7 V1.8.0HAl driver or LWIP . I am facing same issue if checked with standard Nucleo-F767ZI board .
Can you please internally escalate this issue and sort out the problem as soon as possible.
Thank you
