2022-07-09 4:58 AM
can someone give me a recommendation for a 3Port Ethernet-Switch IC, which will work together with AZRTOS. What changes in settings are necessary?
I want to built a system with 2 physical RJ45-Ethernet Ports and a RMII conntection to a STM32F407.
Many thanks for your help
Juergen
2022-07-20 5:09 PM
Any PHY, for which you will implement the driver (that is easy), will work. But ST seems to provide only a driver for LAN8742, which you can take as an example.
https://wiki.st.com/stm32mcu/wiki/Introduction_to_NETXDUO#STM32_Integration
https://github.com/STMicroelectronics/x-cube-azrtos-f4/tree/main/Drivers/BSP/Components/lan8742
