2024-02-11 3:49 AM
I have checked through the inquiries and possible solutions on the ST community for eSIM registration issues on BL462E-CELL1.
However, none has worked for me.
https://community.st.com/t5/stm32-mcus-embedded-software/b-l462e-cell1-not-connecting-to-truphone/td-p/215965
https://community.st.com/t5/stm32-mcus-products/b-l462e-cell1-not-connecting-to-truphone-continued/td-p/166092
I'm in South Korea, and the error I get is;
"ATCModem:NetworkState (EPS) = NOT_REGISTERED_NOT_SEARCHING"
"AT%CEER?<CR> %CEER: 1,"NAS-EMM","ATTACH","REJECT",#11,PLMN_NOT_ALLOWED<CR><LF>"
I have attached the traces from the TeraTerm serial for more details.
- The eSIM is already activated on the Truphone IoT dashboard
- Executing "at at%nwoper?" command gives "TRUPHONE".
- South Korea is covered for LTE-M by Truephone (https://www.truphone.com/things/plans/coverage/?feature=LTE-M&addon=Asia )
The detected IMSI is "204080920719573" which corresponds to the Netherlands - KPN Mobile The Netherlands BV (https://www.numberingplans.com/?page=analysis&sub=imsinr )
I have traveled around to areas with more coverage by the main telecom networks here (SKT, KT, LGU+), but the IMSI hasn't changed, and the error persists.
Can someone check through the TeraTerm log attached, and offer some guidance on resolving the error?
Your help is much appreciated.
Best regards.
2024-02-12 8:14 AM
I resolved the error. With reference to the guidance from @Ronan GABOU (https://community.st.com/t5/stm32-mcus-products/b-l462e-cell1-unable-to-connect-to-network-or-registration-on/m-p/93137#M13091).
I checked this command “at at%getacfg=radiom.config.preferred_rat_list”, and the response was “none”.
Do not “trace off” to see the response.
I used the command “at at%setacfg=radiom.config.preferred_rat_list,"CATM"” to configure Cellular LTE CatM.
After resetting the board, eSIM registration was successful and I could evaluate the echo message & ping examples according to the binary firmware.
I have attached the tera term log for details.
The IMSI is still "204080920719573", but from the traces, it seems Truphone uses data roaming to establish the connection. If someone has a better explanation for this, it would be great to know.
Regards.
2024-02-12 8:14 AM
Regards.
