LAN8742A read io is always 0xFFFF. [STM32H747I-DISCO]
sjeon.11
Associate
Hello Sir.
In STM32H747I-DISCO board​, LAN8742A IC cannot read properly.
Always read only the 0xFFFF value.
In the same source, NUCLEO-H745ZI-Q board reads IO of LAN8742A well.
In LAN8742.c
&regvalue is always 0xFFFF.
 if((pObj->IO.GetTick() - tickstart) <= LAN8742_SW_RESET_TO)
              if(pObj->IO.ReadReg(pObj->DevAddr, LAN8742_BCR, &regvalue) < 0)
                status = LAN8742_STATUS_READ_ERROR;
                break;
            else
              status = LAN8742_STATUS_RESET_TIMEOUT;
 break;
Anyone please help.
1 REPLY 1
TOlli
Senior
I had similar issue on a custom board. The problem was that I had wrong configuration of pins in the LAN8742A. Check any jumpers so that the chip is put into correct mode, you probably want RMII mode.
