2025-05-05 7:40 AM - last edited on 2025-05-07 2:30 AM by Andrew Neil
2025-05-07 2:24 AM
Hello @Furkan2 ,
Thank you for reaching out to us. Could you please confirm if you are using the TouchGFX Designer as your software tool for creating graphics? If so, to ensure the graphics work correctly with your board, it's important to first select the appropriate STM32 board within the TouchGFX Designer. This step ensures compatibility and optimizes the design for your specific hardware.
Once you've completed your design, you can compile and flash it directly to your board using the appropriate firmware and development environment. This process typically involves generating the code from TouchGFX, compiling it using an IDE like STM32CubeIDE, and then programming your board with the compiled firmware.
BR
