2021-06-30 10:49 AM
2021-07-01 1:35 AM
Hello @Community memberov ,
you need to install ActivePerl in order to run the SPL2LL-Converter.
I recommend you to use ActivePerl 5.24.1 or later.
Can you please give me your feedback after the installation?
2021-07-01 2:44 AM
Hi @Community memberov ,
Besides to @houssemeddine 's proposal, I suggest you to use the CLI version of SPL2LL-Converter.
Reference documentation that can help you:
-Amel
2021-07-02 1:30 AM
XML::Parser::Expat object version 2.46 does not match bootstrap parameter 2.44 at C:/Strawberry/perl/lib/DynaLoader.pm line 210.
Compilation failed in require at Modules/XML/Parser.pm line 18.
BEGIN failed--compilation aborted at Modules/XML/Parser.pm line 22.
Compilation failed in require at Modules/XML/Twig.pm line 129.
BEGIN failed--compilation aborted at Modules/XML/Twig.pm line 129.
Compilation failed in require at spl2ll_converter.pl line 50.
BEGIN failed--compilation aborted at spl2ll_converter.pl line 50.
2022-02-10 1:40 PM
I am also seeing the same compile errors!
