2020-11-22 10:57 AM
I I am stuck in my project, I have to activate the physical sim card.
the documentation says you need "Set pin Sim_select0 to low to select the plastic SIM" but I don't know how to do it.
2020-11-23 2:39 AM
i use L496_modem_boot.bin in xcube cellual\STM32CubeExpansion_CELLULAR_V5.2.0\Utilities\Modem_FW\BG96\Pack_BG96MAR02A08M1G_01.012.01.012\Pack_BG96MAR02A08M1G_01.012.01.012
with teraterm i can select SIM in configuration
2020-11-22 2:05 PM
Try the schematic
Sim_Select0 is Pin#19, Sim_Select1 is Pin#9 of the STMOD+ connector, configure and set the pins appropriately on the host board. PB12 and PD3 respectively
https://www.st.com/en/evaluation-tools/32l496gdiscovery.html
2020-11-23 12:57 AM
Thank you for your answer
I know which pin to modify but how do I do it, do I need software?
2020-11-23 2:39 AM
2022-01-27 12:03 PM
The best answer !
2022-01-27 11:00 PM
Thank you!
