2013-07-18 11:18 AM
Hello guys, I need some help. Im trying to interface a stm32f407 with a lan8720 via RMII interface using an external clock source from the PHY.
I was able to measure the 50MHz sine wave generated by the PHY, but I can't see any comunication between chips. I mean, MDC is always low and MDIO is always high (because there's a pull up resistor). Below is the code. I'm pretty sure that there's a problem related with the external reference clock. It seems like the MAC it's not running. I think there's something wrong configured. The code is based on [DEAD LINK /public/STe2ecommunities/mcu/Lists/cortex_mx_stm32/Flat.aspx?RootFolder=/public/STe2ecommunities/mcu/Lists/cortex_mx_stm32/MDC%20MDIO%20stay%20low%20forever%20after%20configuring%20RMII%20%20Ethernet%20on%20STM32F4&FolderCTID=0x01200200770978C69A1141439FE559EB459D7580009C4E14902C3CDE46A77F0FFD06506F5B¤tviews=520]this post. Best regards!void ETH_GPIO_Config(void)
uint16_t i = 0;
// Data structure to represent GPIO configuration information
// Enable the peripheral clocks
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA | RCC_AHB1Periph_GPIOB |
RCC_AHB1Periph_GPIOC | RCC_AHB1Periph_GPIOD,
ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_SYSCFG, ENABLE); // Early
// Configure PD8 (RMII_nRST)
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL ;
GPIO_Init(GPIOD, &GPIO_InitStructure);
// Hold the Ethernet PHY in reset
GPIOD->BSRRH = 0x100;
// Set RMII mode while in reset
SYSCFG_ETH_MediaInterfaceConfig(SYSCFG_ETH_MediaInterface_RMII);
//GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
// Configure PA1, PA2 and PA7 (RMII_REFCLK, RMII_MDIO, RMII_CRS_DV
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1 | GPIO_Pin_2 | GPIO_Pin_7;
GPIO_PinAFConfig(GPIOA, GPIO_PinSource1, GPIO_AF_ETH);
GPIO_PinAFConfig(GPIOA, GPIO_PinSource2, GPIO_AF_ETH);
GPIO_PinAFConfig(GPIOA, GPIO_PinSource7, GPIO_AF_ETH);
// Configure PB11 (RMII_TXEN), PB12 (RMII_TXD0), PB13 (RMII_TXD1)
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11 | GPIO_Pin_12 | GPIO_Pin_13;
GPIO_Init(GPIOB, &GPIO_InitStructure);
GPIO_PinAFConfig(GPIOB, GPIO_PinSource11, GPIO_AF_ETH);
GPIO_PinAFConfig(GPIOB, GPIO_PinSource12, GPIO_AF_ETH);
GPIO_PinAFConfig(GPIOB, GPIO_PinSource13, GPIO_AF_ETH);
// Configure PC1, PC4 and PC5 (RMII_MDC, RMII_RXD0, RMII_RXD1)
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1 | GPIO_Pin_4 | GPIO_Pin_5;
GPIO_Init(GPIOC, &GPIO_InitStructure);
GPIO_PinAFConfig(GPIOC, GPIO_PinSource1, GPIO_AF_ETH);
GPIO_PinAFConfig(GPIOC, GPIO_PinSource4, GPIO_AF_ETH);
GPIO_PinAFConfig(GPIOC, GPIO_PinSource5, GPIO_AF_ETH);
for(i = 0; i <
20000
; i++); // PHY Out of reset
GPIOD->BSRRL = 0x100;
ENABLE);
for(i = 0; i <
20000
#stm32 #discovery #ethernet-phy
2013-07-18 12:06 PM
The link doesn't work for me.
The code doesn't look wrong. You are aware the PHY is at a different address than the DP83848, right?2013-07-18 12:26 PM
Hi Clive1,
Thank you for your answer. I read it somewhere, but should I worry about that now? Or I'm missing something? Because, for me, the main problem is I can't establish the comunication between mac and phy =/. But as Im a newbie with ethernet and st maybe there's something I'm missing.Did you use the 50MHz source clock from lan8720? Or from the MCO pin?Best regards!2013-07-18 1:45 PM
The design I looked at generated 25 MHz out the MCO pin from the HSE. The SMSC8720A was strapped to use a 25 MHz source. You could perhaps use MCO to generate 50 MHz if the PLL ran the CPU at a multiple of 50 MHz (ie 150 MHz).
2013-07-18 2:09 PM
Yes, I can use the MCO, but I will have to redesign my board and I want to avoid it.
I've realize that the 25MHz signal generated by the crystal it's mounted on a 3KHz ''almost sine'' wave O.OAnd the 50MHz output sine is mounted on a 6KHz sine. That is wear and I don't why it happends. I am totaly confused.2013-07-18 5:02 PM
What do you have right now as a clock source (part#), and what pins is that attached too?
2013-07-18 5:18 PM
Well, I was, finally, able to get it work. The code is the same used in
http://www.backwoodsengineer.com/2013/02/geeky-post-stm32f4-bb-ethernet-projects.html
. The low frec sine mounted on the crystal was present in the stm32f4 8MHz crystal too. And I measure in another board and same situation, so it could be my osc or I don't know, lol. Thank you for all clive1, I really appreciate your help. Best regards,void ETH_GPIO_Config(void)
volatile uint32_t i;
/* Enable GPIOs clocks */
| RCC_AHB1Periph_GPIOC | RCC_AHB1Periph_GPIOD, ENABLE);
/* Enable SYSCFG clock */
/* MII/RMII Media interface selection --------------------------------------*/
/* Ethernet pins configuration ************************************************/
ETH_MDIO --------------> PA2
ETH_MDC ---------------> PC1
ETH_RMII_REF_CLK-------> PA1
ETH_RMII_CRS_DV -------> PA7
ETH_MII_RX_ER -------> PB10
ETH_RMII_RXD0 -------> PC4
ETH_RMII_RXD1 -------> PC5
ETH_RMII_TX_EN -------> PB11
ETH_RMII_TXD0 -------> PB12
ETH_RMII_TXD1 -------> PB13
ETH_RST_PIN -------> PE2
/* Configure PA1,PA2 and PA7 */
/* Configure PB10,PB11,PB12 and PB13 */
/* Configure PC1, PC4 and PC5 */
/* Configure the PHY RST pin */
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
GPIO_ResetBits(GPIOD, GPIO_Pin_8);
for (i = 0; i < 20000; i++);
GPIO_SetBits(GPIOD, GPIO_Pin_8);
