2020-02-09 3:24 AM
why does this work:
HAL_UART_Transmit_DMA(&huart6, (uint8_t *)"stm32\n", 6); // works and sends data
and this doesnt:
ALIGN_32BYTES (uint8_t aTxBuffer[]) = "stm32\n";
HAL_UART_Transmit_DMA(&huart6, (uint8_t *)aTxBuffer, 6) // doesnt send any data
what am i missing?
2020-02-09 4:36 AM
solved! appreciate the quick responses, thank you!
for anyone whose reading this and having the same issue: this is what you're looking for https://community.st.com/s/article/FAQ-DMA-is-not-working-on-STM32H7-devices
2020-02-09 3:49 AM
Most likely aTxBuffer is located in DTCM, to which only the MDMA has access in H7 series. Take a look at AN4891 figure 1.
2020-02-09 3:51 AM
DMA buffers must be located in (the appropriate) RAM. Fixed strings or other constant data are usually stored in ROM (flash).
You should verify/ensure that the data is provided on stack / RAM.
2020-02-09 4:36 AM
2020-02-24 5:30 AM
Glad to know that your question is answered. Please mark the article as helpful in this case.
Thanks
Amel
