2023-07-26 1:30 PM - last edited on 2023-08-07 6:14 AM by Amel NASRI
I've downloaded the x-cube_classb application, but none of the projects will build for EWARM
In addition to a few warnings, the linker fails:
EWARM version: 9.30.1.50054
Compiler version : 9.30.1.335
2023-10-16 5:31 AM
as visible from table "STL code size and data size (in bytes)" at user manual, the STL needs ~220 bytes at RAM only. Area 0x2000'0030-0x2000'1fff should be sufficient enough to allocate that. Check your linker file setting (stack/heap size).
Best regards,
Petr
Best regards,
Petr
