2026-04-20 8:14 PM - last edited on 2026-04-21 12:59 AM by Gyessine
uint8_t W25N_status(void) {
QSPI_CommandTypeDef cmd = {0};
uint8_t status;
cmd.InstructionMode = QSPI_INSTRUCTION_1_LINE;
cmd.AddressMode = QSPI_ADDRESS_1_LINE;
cmd.AddressSize = QSPI_ADDRESS_8_BITS;
cmd.Address = 0xC0;;
cmd.DataMode = QSPI_DATA_1_LINE;
cmd.NbData = 1;
cmd.Instruction = 0x0F; // read status register
if (HAL_QSPI_Command(&hqspi1, &cmd, HAL_MAX_DELAY) != HAL_OK)
return 0xFF;
if (HAL_QSPI_Receive(&hqspi1, &status, HAL_MAX_DELAY) != HAL_OK)
return 0xFF;
return status;
uint8_t W25N_reset(void) {
cmd.AddressMode = QSPI_ADDRESS_NONE;
cmd.DataMode = QSPI_DATA_NONE;
cmd.Instruction = 0x66; // enable reset
return 1;
cmd.Instruction = 0x99; // reset
return 1;
HAL_Delay(5); // delay to allow full reset (tRST is max 500ums)
return 0;
uint32_t W25N_read_id(void) {
uint8_t read_data[3];
cmd.DummyCycles = 8;
cmd.NbData = 3;
cmd.Instruction = 0x9F; // read JEDEC id
return 0xFFFFFFFF;
if (HAL_QSPI_Receive(&hqspi1, read_data, HAL_MAX_DELAY) != HAL_OK)
return 0xFFFFFFFF;
return (read_data[0] << 16) | (read_data[1] << 8) | read_data[2];
uint8_t W25N_read(uint32_t start_page, uint16_t offset, uint32_t size, uint8_t *data) {
// load flash page
cmd.AddressSize = QSPI_ADDRESS_24_BITS;
cmd.Instruction = 0x13;
cmd.Address = start_page;
return 1;
// HAL_Delay(5);
// read flash segment
cmd = {0};
cmd.AddressSize = QSPI_ADDRESS_16_BITS;
cmd.DataMode = QSPI_DATA_4_LINES;
cmd.NbData = size;
cmd.Instruction = 0x6B;
cmd.Address = offset;
return 1;
if (HAL_QSPI_Receive(&hqspi1, data, HAL_MAX_DELAY) != HAL_OK)
return 1;
return 0;
uint8_t W25N_block_erase(uint32_t block) {
cmd.AddressMode = QSPI_ADDRESS_NONE ;
cmd.Instruction = 0x06; // write enable
return 1;
cmd = {0};
cmd.Address = block * 64;
cmd.Instruction = 0xD8; // block reset
return 1;
HAL_Delay(10); // delay to allow full reset (tBE is max 10ms)
return 0;
uint8_t W25N_program_data(uint32_t page, uint16_t offset, uint16_t size, uint8_t *data) {
return 1;
cmd = {0};
cmd.NbData = size;
cmd.Instruction = 0x34; // Quad Random Load Program Data
return 1;
if (HAL_QSPI_Transmit(&hqspi1, data, HAL_MAX_DELAY) != HAL_OK)
return 1;
cmd = {0};
cmd.Address = page;
cmd.Instruction = 0x10; // program execute
return 1;
return 0;
}2026-04-23 3:20 AM
Hello @chris7777
Don’t use HAL_MAX_DELAY while debugging. If QSPI flags never complete, the HAL will block forever and it looks like the whole MCU hung. Use a short timeout and check the returned error code.
