2016-01-19 3:40 AM
Hi
I've noticed annoying bug in STM32CubeMX. When I'm generating code for FATFS, the ffconf.h file in inc folder has only comments header. It casue compilation error. Please fix this quickly.I'm developing now application on STM32F373RCTx but same bug is showing up for STM32F3DISCOVERY, for other uC series is everything ok.Regards,Dawid #bug #stm32cube2016-01-20 4:18 AM
Hi Dawid,
Could you precise on which CubeMX version you have found the issue. So, we can verify it.-Syrine-2016-01-21 12:03 AM
Dear user,
We reproduce your issue on Linux OS and on F0 series as well. This will be fixed in next STM32CubeMX release 4.13. As a workaround for now, you can go to STM32CubeMX installation directory, and rename the fatfs_conf_F3.ftl into fatfs_conf_f3.ftl in the db/templates folder. Best regardsWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
