2015-10-08 2:02 PM
CubeMX v4.10.1, everything is updated.
I'm trying to configure PA0 & PA1 to GPIO Output, Open Drain, Pull-up. CubeMX does not save the configuration and does not modify my project properly. #bug #stm32cube2015-10-09 8:39 AM
Hi m.e,
I confirm that the behaviour is aleatory when user change pin configuration, sometimes the modification is generated correctly in the code and sometimes not. Now, I recommend you to save your modifications by ticking ''Apply'' button. And the issue is reported for investigation. -Shahrzad-We’re moving the ST Community to a new platform to give you a better and more reliable community experience.
