Resolved! FatFs_USBDisk example with USB_FS does not work. When an USB Stick is connected the USBH_MSC_Process never gets further then MSC_READ_INQUIRY. Any hints?
I am trying to implement an USB logger. I have initially started with the F769 Discovery Board what worked fine using the USB_HS implementation. Because my final hardware does use USB_FS and I do not own an F769 Eval Board I tried the FatFs_USBDisk e...
MMenz.1 by Associate III
  • 5123 Views
Resolved! Safety self-test library fails the TM12 test module
What I'd like to ask on this community forum is, has anyone faced any issue integrating the STL library? An FAE is engaged on this issue, with no response as of yet. We have good overall success, with the exception of the TM12 module, which fails occ...
DamienF by Associate II
  • 3891 Views
FreeRTOS libraries for USB audio dongle.
Hello, For the B-U585I-IOT02A device with FreeRTOS, I want to plug an USB audio dongle into the board, and want to get/put audio data from/to the USB audio device, but when I searched the FreeRTOS APIs, it seems that there's no standard APIs for gett...
IChoi.2 by Associate
  • 1460 Views
I2C Master send incorrect data
STM32F103C8Cube IDE 1.10Greeting,I tried to send data (count from 13 to 15 every 500ms) thru i2c1 using HAL_I2C_Master_Transmit.slave is pcf8574, scl & sda line pulled up with 3k3 resistor.usb scope shows master send correct address, but data always ...
Arobb.1 by Associate
  • 3049 Views
