STM32N6 calculate frame difference
Hi all,I'm having a go at programming on the STM32N6570-DK. My goal final goal for this little project is to show the difference in pixel values between the first frame and current frame. This is usually done in vision systems to "filter" out the sta...
Resolved! STM32N6 BootROM flash boot XSPI port
Hi,I have a question regarding the STM32N6 BootROM flash boot process.My understanding is that the BootROM loads the FSBL from an external XSPI flash device. However, it is not clear to me whether the BootROM:Uses a fixed XSPI/XSPIM configuration (fo...
ArunJohn by Associate II
  • 104 Views
Resolved! DMA: Start transfer from address + offset
Hi, I want to use my F072's DACs to output a sin and cos signal. to save on memory I want to have only one buffer holding the values of a SIN function, COS values should be taken from the same buffer. Basically, I need the DMA for channel 1 to start ...
GChri.2 by Associate II
  • 113 Views
Resolved! UART TX/RX with DMA in Normal mode
Dear ST experts,I have configured UART (both RX and TX) in Normal DMA mode. I want to send a small data packet every 500 ms with using HAL_UART_Transmit_DMA (&huart, buffer, 10). But I noticed that only one shot is triggered. What is the problem? Sho...
