Resolved! STM32f429 disc1 board
Can I know what is difference between internal adc of STM32f429 disc1 board and an external 12bit 1MSPS adc.Which adc to use for any application that needs more accuracy whether I should go for external or internal adc.Will internal adc produces any ...
harry123 by Senior II
  • 1174 Views
factory-set programming
Hello,I work in a company that uses stm32F031C4T6 and we manufacture 40,000 cards a year with this reference. I was wondering if it would be possible to ask the manufacturer to program the microcontrollers directly in their factories, because for our...
kolia by Associate
  • 1135 Views
Resolved! NetX Duo driver & link-down state
Hi All,I am working at project with STM32H7 and NetX Duo. At current version of Ethernet driver from ST (X-CUBE-AZRTOS-H7 v3.0.0) is not handled by any way state when link is disconnected. Link status variable nx_interface_link_up is set at "Enable L...
JDosp.1 by Associate III
  • 7043 Views
  • 4 kudos
Resolved! PWM with DMA makes unwanted pulse stream
Hi,I want to make PWM stream with various duty, so I'm testing PWM with DMA using NUCLEO-G0B1RE and HAL library.The first image shows weird pulse train. I set DMA buffer with [duty 1] * 8 + [duty 17] * 8 + [duty 5] * 8, but oscilloscope captures eigh...
click8 by Associate II
  • 4980 Views
STM32F767 Ethernet at different rate
Hi everyone. I'm using stm32f767zi board with lwip stack and I need to transmit at different rate through Ethernet: 50mbit/s, 80mbit/s and 100mbit/s. When I tried to send a buffer of 6554 byte every 1ms (in order to send 6553600 byte aka 50mbit every...
Al3 by Associate II
  • 8782 Views
  • 14 replies
EEPROM Emulation in FLASH STM32L432KC
I am working on EEPROM Emulation in STM32L432 using its internal flash memory so is there any specific address for making EEPROM emulation in stm32l432kc or can we take any random address of flash memory? give the solution.
vpn by Associate
  • 1658 Views
