STM32H755 with Precision Time Protocol.
Hello all,I am learning to implement a bare-minimal code that let PTP(OC, slave mode) works with STM32H755(Nucleo-H755ZI-Q with FreeRTOS). I have read RM0399, UM2217 as well as stm32h7xx_hal_eth.c with corresponding chapters. And here is the first dr...
Leon_MS by Associate III
  • 7696 Views
  • 11 replies
Enable ARP Offload on STM32H753
Hi,I try to enable the hardware ARP Offload in a STM32H753 custom board. The problem is, that it doesn't take the given IP adresse in die MACARPAR register regardless what the sequence of code is. I tryed it before and after enabling the ARPEN bit an...
ASitt by Associate
  • 2167 Views
Low-power sleep mode
Not able to send STM32L4S9ZIJ6 into low-power sleep mode even after using inbuilt sleep API calls. Have used HAL_PWR_EnterSLEEPMode function call after configuring SLEEP_PD register, configuring system clock to run at 2MHz & changing the regulator mo...
Anup123 by Associate
  • 1657 Views
Resolved! How to stop debug messages in lwIP?
HiI have a project using lwIP, created by STM32Cube.It works fine, but I really want to shut OFF the debug messages.I have searched and tried a bunch of different things, but nothing seems to be able to stop it. Example of error/debug message: "netif...
KKjel.1 by Senior
  • 3959 Views
