BOOT0 pin problem on STM32F302RE
Hello, I use STM32 for years, and on a new board I use for the first time a F3 series : STM32F302REI use exactly the same schematic as all my previous board, and for the BOOT0 pin, I have a 2.2K pull-up pull-down, and a jumper to set the pin to 3.3V ...
USB_PD HPD VDM Send Attention Message
I'm working with USB_PD through a nucleo sink and a G474ER and want am receiving the ACK/Good CRC messages that are started from the laptop side (DIscover identit, discover SVID, Discover Mod, Enter Mode, dp status, dp config), but am unable to get t...
FP-AUD-AEC1 on NUCLEO-F446RE, X-NUCLEO-CCA01M1 and  X-NUCLEO-CCA02M2 following UM2824 - Rev 2 & Quick Start Guide Version 1.0 (Jan, 2021)
Hardware:NUCLEO-F446RE,  X-NUCLEO-CCA01M1,  X-NUCLEO-CCA02M2Software:Downloaded from STM: V1.2.0 and V1.1.0Github: V1.2.0 Hi, I am attempting to get sound output from the sound terminal expansion board CCA01M1 with no luck. I managed to follow UM1979...
OceanPlumber_1-1725432897717.png OceanPlumber_0-1725432879596.png OceanPlumber_2-1725433013402.png OceanPlumber_3-1725433045624.png
Resolved! STM32U535CET6 USBX
Hello,I'm trying to get USBX CDC Virtual COM Device configured on an STM32U535CET6.  I have downloaded and tried to play matchup with the projects out on GitHub for the U5 series but have had no success.  I'm currently stuck on: /* Now check for inva...
Resolved! USBX, Detect cable disconnected.
I am running the "Ux_Device_HID_CDC_ACM" example project on a NUCLEO-H563ZI board.The example runs without issues, i can attach and remove the usb cable and the mouse connection appears and disappear.The issue is that the USB-stack does not seem to d...
Henrik76 by Associate
  • 1486 Views
Resolved! about STM32 Timer using HAL lib
Hello, I am now try to do a BLDC motor driver with STM32G474. I used the tim1 to get the 3 channel PWM and PWMN to drive the 3 full bridge with 6 step solution. the problem is, I referred someone's code. the code is like below: // Bridge FETs for Mo...
dqsh06 by Senior
  • 2853 Views
