Enabling HTTPd breaks the whole project
Hi, I'm playing around with lwIP on my Nucleo-H743ZI and I was able to make ping work, udp/tcp echo and snmp too. But when I enable HTTPd the project doesn't wont do compile I just get a lot of undefined references, I tried to make a new project and ...
abeslic by Associate II
  • 14510 Views
  • 15 replies
  • 10 kudos
interfacing PSRAM using FMC
Hi allI have used CubeMx to create an FMC interface to psram(nonmultiplex) 8-bit data 10-bit addressThe data is valid on the rising edge of the fourth clock To have correct data on the data pins the pointer to write data (psram64) must be a 64-bit po...
dorong by Associate II
  • 1188 Views
REST API on STM32F4 with lwIP
Dear all,I am using lwIP over STM32F4 and I would add REST API to my project.I try to understand how to do that, and the only way that I have found is to use CGI. The problem is the reply: I can reply only with a static file present in the SDCARD (th...
LFerr.3 by Associate
  • 2242 Views
