Help with a seemingly constant RxHeader.
I am working with a CAN bus over a STM32 Board. I don't think the hardware is important in my question. I have tried to use the HAL_FDCAN_GetRxMessage function to get a message from a device explorer where you can easily send a message via CAN. I run...
CANGWP by Associate
  • 1139 Views
STM32H745 Pinging
Hello everyone,   I am trying to establish a connection between my STM32H745I(Discovery kit) and my computer and the jumpers are set to STLK for programming, and I also have connected the board through LAN to my computer directly. I have set my compu...
FatFS and D-Cache not working together
Issue with FatFs and D-Cache on STM32 (CubeMX Library)I'm having issues using FatFs with D-Cache enabled on an STM32. After searching, I found several posts reporting similar problems, but I haven't seen a clear solution.I’m using the FatFs library t...
How config I3C Target to send NACK
Hi, I would like to know how to disable address acknowledgment in I3C when operating as a target (with an already assigned address) to temporarily hold communication, similar to the OA1EN bit in I2C.Thanks,
RFerr.3 by Associate II
  • 3608 Views
memcpy() function not working
Hi,I'm using the STM Cube IDE version 1.15.1 along with NucleoG474RE board. My C application requires the use of memcpy(). The memcpy() function should copy the values from an unsigned char source buffer to the unsigned char destination buffer. This ...
