DFU/RS232 FW update
Posted on October 04, 2012 at 15:21Hi,I came to the stage where I want to upload my own FW into the STM3220-EVAL board running on STM32F207 CPU.My first attempt was to use original ST DfuSe utility. I was trying to run bot 32 and amd64 bit versions ...
dimax by Senior
  • 7212 Views
A problem in STM32F103 and FreeRTOS environment
Posted on October 23, 2012 at 09:14Hi all,I have written complete description of my problem at FreeRTOS forum( Sourceforge.net). I think rewriting the entire problem is no required again. Hope you will understand, please follow the link: https://sou...
harinath by Associate III
  • 983 Views
STM32f4-Discovery SDIO problems
Posted on July 12, 2012 at 13:52Hi, I have been trying to get SDIO to work on an STM32f4-Discovery board using the std-periph library and the mass storage class example from the USB device library. I was able to get SDIO+FatFs+USB to work but it wor...
tavish by Associate II
  • 2724 Views
Bootloader
Posted on October 05, 2012 at 10:53Hello I am using STM32F2XX series. And I am new to controller programing. I am using in built bootloader currently. If in case if i want to have a firmware upgrade feature, what are the changes needs to be done at...
logger and MSC with fatfs
Posted on October 11, 2012 at 17:16 Hello experts and sorry to bother you once more. I implemented a FW for a STM32F102CB that combines logging and USB MSC (Mass Storage Class). I took the USB MSC from STM32_USB-FS-Device_Lib_V3...
michele77 by Associate II
  • 1398 Views
Lot of problems with ST applications
Posted on August 16, 2012 at 10:00Hello, first I apologize if my English is not very good. It's not my primary language. I'm quite new to the STM32 world. I'd like to try some tools provided by ST. The first two downloaded give a lot of troubles. 1)...
Mark81 by Associate III
  • 3609 Views
Porting of HID USB on FreeRTOS
Posted on January 26, 2012 at 19:27Hi I am having issue of porting USB to FreeRTOS environment, Windows pops up and message in task bar saying ''Unknown Device ''   Please help., Does it mean USB it set at wrong clock, USB used to be so simple on ST...
